Hi All,
Hopefully a really quick question. Is there any reason why I wouldn't want to use a B450 mobo with the new Ryzen 3400G? They are still on the 12nm+ node and I believe the Vega graphics is the exact same too (higher clock) so I don't think there is anything significant that changed on that side of things. I know the socket is still good, I am more concerned about the chipset. The 5XX chipsets seemed to focus on PCI 4.0 and other things I didn't need, but I don't want any compatibility issues. I'm not going to OC, this is just for a basic HTPC now that the 3XXX series APUs can handle 4K HDCP/Netflix.
I am building a Mini ITX build (Cooler Master Elite 110 case) and Mini ITX mobos are few and far between. This one went on sale with a $30 rebate and I wanted to grab it if I can be sure it'll work just fine:
https://ca.pcpartpicker.com/product...ac-mini-itx-am4-motherboard-b450-gaming-itxac
TDP of the 3400G is only 65W so I think I should be OK with those VRMs.
Was also looking at the MSI equivalent "B450I Gaming Plus" mITX board which apparently has better VRMs but a really bad BIOS.
TIA
TIA
