In order for you to move towards the i9 platform, you're going to have o invest on other components as well. What are the specs of your current system? List them like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Include the games you're interested in playing and streaming to Twitch.
You already have two "capture" cards in your system right now,the integrated GPU has QSV usable by OBS and your nvidia card has nvenc usable also by OBS and by geforce experience,so you can check beforehand if it will make a difference, capture cards come in two variants the cheap ones still rely on CPU power to make the stream more expensive ones have a hardware codec just like your GPUs.Will adding a capture card make a difference with the quality of the stream?
