I am not sure if this is a stupid question... might be...
My San Diego is rock solid at 2.8Ghz (from 2.2) 1.55V 30C-40C
If I get an aftermarket HSF and drop the temps... at the exact same voltage... should I be able to get a higher stable clock?
I was under the impression it was volts that stabilize an overclock and low temps just make the volts safer...
so... the question once more
At the same voltage, should lower temps yield a higher Overclock?
