Will a Cooler Master MasterAir Maker 8 fit in my case and not be too heavy?? HELP!!
Luke2468
197
Hi i have an NZXT H440 case and was wondering if the Cooler Master MasterAir Maker 8 would fit my case? And also i have an MSI Gaming 5 z97 board and was wondering if it'd be too heavy for the board. Thanks for any help and advice!
YES IT FITS , THE COOLER is a little over 160mm , your case supports CPU Cooler: 180mm , and when the mounting hardware is used correctly they are perfectly safe to mount on your board.
Thanks for the quick response and okay i just read that someone put it didn't fit for some reason and someone else said youd need a high quality board with a thick pcb...thanks for the clarification!!
