A Azzagun Honorable May 16, 2014 62 0 10,630 Aug 29, 2014 #1 I have a Cooltek Xanthos case and i cant seem to find any info on wether if i can fit a Corsait H100i into it seeing as i want to oc my I7-4790K
Solution LukaBoki Aug 29, 2014 Yes. http://www.cooltek.de/en/midi-tower/xanthos/38/xanthos "Two 120 mm ventilators can be mounted under the top cover" http://www.corsair.com/en/hydro-series-h100i-extreme-performance-liquid-cpu-cooler "Fan Specification 120mm (x2)" You're good to go.
LukaBoki Splendid BANNED Jul 12, 2014 4,392 1 25,815 Aug 29, 2014 Solution #2 Yes. http://www.cooltek.de/en/midi-tower/xanthos/38/xanthos "Two 120 mm ventilators can be mounted under the top cover" http://www.corsair.com/en/hydro-series-h100i-extreme-performance-liquid-cpu-cooler "Fan Specification 120mm (x2)" You're good to go. Upvote 0 Downvote Solution
A Azzagun Honorable May 16, 2014 62 0 10,630 Aug 29, 2014 #3 LukaBoki : Yes. http://www.cooltek.de/en/midi-tower/xanthos/38/xanthos "Two 120 mm ventilators can be mounted under the top cover" http://www.corsair.com/en/hydro-series-h100i-extreme-performance-liquid-cpu-cooler "Fan Specification 120mm (x2)" You're good to go. ok thx Upvote 0 Downvote
A Azzagun Honorable May 16, 2014 62 0 10,630 Aug 29, 2014 #5 LukaBoki : No problem. also do you have any idea how to remove the top cover ? Upvote 0 Downvote
LukaBoki Splendid BANNED Jul 12, 2014 4,392 1 25,815 Aug 30, 2014 #6 Just give it a push.Be careful not to break anything though. Upvote 0 Downvote
