Will a corsair H110i GTX fit into my Zalman Z11 plus case?
grundles
108
Before I go buying this cooler I was wondering if it would fit along with an ATX mobo, 4sticks of ram and a rear fan. The mobo I have is an asrock z170 extreme 6 just in case there's anything on it protruding that might not let me use this cooler.
Its all about fan and radiator mounting. Do you need liquid? Have you considered a more reliable, cheaper, quieter, big dumb block of metal with a good quality fan than cools just about on par?
Noctua U14s or D15. No pump noise (they will get louder over time), no possible pump failure. Less stuffing around
