Will a Cryorig H7 fit in a Phantom 820 case?
Hello,
The answer to the "will it fit in the case" question is simple, yes.
Your motherboard a the default answer "yes" but.. today i had a customer wich wanted the Cryorig H7 and it fitted 99%, expect.. there was a resistor that was a bit to high in the cpu section
I checked your motherboard but you should be fine =)
Dion__
156
Hello,
