Will a dark rock advanced C1 fit inside a 300r?
I've heard better things about the Phanteks, and a lower profile can help just because it allows more airflow through the rest of the case, but it shouldn't matter too much.
Yeah i already have that sorted by grabbing some low profile RAM, thanks i may go with the dark rock then. Do know if the Phanteks PH-TC12X-RD will be just as good? They are same price but the phanteks is smaller in height
Thank you, i will go for the phantek due to what you've heard and its also smaller.
Ah, no problem. CPU coolers can completely stop 90% of the airflow from front to back or back to front when they're as big as those. If you could give me the best solution I would appreciate it, lets me be more helpful. Also I like badges.
Haha yeah thanks, and yeah i already did.
