Will a dell motherboard fit in another case?
SniiKz
110
Hi Eveyone, I've recently gotten some new Graphics cards and I wanted to install them into my Dell Optiplex 7010, however the graphics cards are to large and will not fit into the case. I want to find a case that is capable of fitting my Dell Optiplex 7010, and the graphics cards as well.
Graphics Cards:
EVGA GeForce GTX 650 Ti
ATI RADEON HD 5670
Thanks Everyone!
Which form factor of the 7010 do you have? Even if you do happen to move it to another case successfully, the front panel connections may not work properly from the chassis.
OEM machines are designed specifically which whatever components it is compatible with from the OEM manufacturer.
