C Craftkrix Commendable May 26, 2016 23 0 1,520 Jul 29, 2016 #1 Will a EVGA SuperNOVA 750B1 750W psu fit into the fractal design define nano s?
Solution MauveCloud Jul 29, 2016 reedo_43 : yes it will fit... Is google broken today? Are you sure about that? Details at http://www.evga.com/Products/Product.aspx?pn=110-B1-0750-VR say the psu in question is 165mm long. Or am I looking at the wrong model?
reedo_43 Splendid Feb 18, 2010 6,195 3 29,965 Jul 29, 2016 #2 http://www.fractal-design.com/home/product/cases/define-series/define-nano-s-window Up to 160mm deep power supplies. Upvote 0 Downvote
C Craftkrix Commendable May 26, 2016 23 0 1,520 Jul 29, 2016 #3 reedo_43 : http://www.fractal-design.com/home/product/cases/define-series/define-nano-s-window Up to 160mm deep power supplies. so yes or no? Upvote 0 Downvote
reedo_43 Splendid Feb 18, 2010 6,195 3 29,965 Jul 29, 2016 #4 yes it will fit... Is google broken today? Upvote 0 Downvote
MauveCloud Splendid May 7, 2010 2,829 0 21,960 Jul 29, 2016 Solution #5 reedo_43 : yes it will fit... Is google broken today? Are you sure about that? Details at http://www.evga.com/Products/Product.aspx?pn=110-B1-0750-VR say the psu in question is 165mm long. Or am I looking at the wrong model? Upvote 0 Downvote Solution
reedo_43 Splendid Feb 18, 2010 6,195 3 29,965 Jul 29, 2016 #6 Not 100% sure. Tough to nail down the exact model. I would suggest he contact evga to be sure. Upvote 0 Downvote
C Craftkrix Commendable May 26, 2016 23 0 1,520 Jul 29, 2016 #7 reedo_43 : Not 100% sure. Tough to nail down the exact model. I would suggest he contact evga to be sure. Or go with another psu Upvote 0 Downvote
