F Fleischer21 Prominent May 6, 2017 4 0 510 May 6, 2017 #1 Hey, I was wondering if a GeForce GTX 1080 Ti will fit in to my computer case? Thanks you for your answers !
Solution Dark Lord of Tech May 6, 2017 Card is 10.5" Case allows 10.62" Should fit but is very very close according to specs.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,737 1,824 159,590 May 6, 2017 #2 Which 1080ti? Upvote 0 Downvote
F Fleischer21 Prominent May 6, 2017 4 0 510 May 6, 2017 #3 Which 1080ti? GEFORCE GTX 1080 Ti Developer edition I think, the one that you can buy from Nvidia's official website. https://www.nvidia.com/en-us/geforce/products/10series/geforce-gtx-1080-ti/ Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,737 1,824 159,590 May 6, 2017 #4 FE that is thanks. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,737 1,824 159,590 May 6, 2017 Solution #5 Card is 10.5" Case allows 10.62" Should fit but is very very close according to specs. Upvote 0 Downvote Solution
F Fleischer21 Prominent May 6, 2017 4 0 510 May 6, 2017 #6 FE that is thanks. Oh damn, so does it mean that I wont be able to use it ? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,737 1,824 159,590 May 6, 2017 #7 I reposted above had my numbers backwards , very very close but should fit. Upvote 0 Downvote
F Fleischer21 Prominent May 6, 2017 4 0 510 May 6, 2017 #8 I reposted above had my numbers backwards , very very close but should fit. Oh ok, Thanks ! Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,737 1,824 159,590 May 6, 2017 #9 Glad to assist. Upvote 0 Downvote
Vic 40 Titan Ambassador Oct 22, 2013 20,976 1,024 88,990 May 6, 2017 #10 You could take the top hdd bay out and you'll have enough room for the longest cards. They only talk about supported gpu length with the hdd bay in. Upvote 0 Downvote
