I currently have a prebuilt system from Acer, which has a "MS-7829 VER 1.1" motherboard and a "NVIDIA Geforce GTX 745 (OEM)" graphics card inside.
I would like to replace the GTX 745 graphics card with a GTX 980 4GB, but I am not sure if the card will fit in a Micro-ATX board (the MS-7829). The dimensions of the card seem much higher than the old 745, so I would like to know if known incompatibilities are known with such a card and motherboard.
Also, I would like to know what is the real difference from a ZOTAC, EVGA, MSI or ASUS PCIE for the GTX980 (appart from the price). Are they usually much different in size? Which do you recommend? I believe I want to go for the MSI PCIE GEFORCE GTX980 GAMING 4G 4GO BTE DDR5, which is 10.98" x 5.51".
TL;DR: I want a GTX 980 cuz the 745 sucks and I dont know if it will fit in a Micro-ATX board.
Thanks.
Thanks.
