Hi, I'm looking to start a new build (first time) and i'm not sure if the GPU I'm looking at will fit in the case, if it 100% won't I'll just use a model with a 2gb frame buffer from Zotac.
Anyways, the card(Gigabyte GTX 960 4gb) is 262mm, and the Cooler Master Elite 350 says that it will only accommodate a 230mm card. Can I remove an optical drive bay or something so that the card will fit or am I stuck with the Zotac model?
