Purpose of that vid was to show it'll run on older generations. Might get a little better performance, the 1030 isn't much of a gaming card. Though it only draws 35w from the Pcie slot. If you had an 300watt PSU i'd suggest looking at a GTX 1050 instead. But only if you knew your Pcie slot provides 75w power. I can't find any documentation or manual for your board so if a 1050 interests you and still have your motherboard manual it should say in there what wattage the Pcie slot is. Sometimes wattage is labelled near the pcie slot.
GTX 1050/1050Ti can also be slot powered with some overclocked models needing additional power. Power consumption of 1050 & 1050Ti
https://www.tomshardware.com/reviews/nvidia-geforce-gtx-1050-ti,4787-6.html
If you have less then 300watt PSU, stay with the 1030 as it only draws 35w. Just don't expect too much from it.
GPU hierarchy chart to see which category the 1030 is with similar cards in it's class of performance. Albeit older cards that do perform similar requires more power so the 1030 does well for being a 35w card.
https://www.tomshardware.com/reviews/gpu-hierarchy,4388.html
I would suggest second hand 750Ti slot powered version to even out a cpu bottleneck compared with the 1050 but there are a lot of fakes going around not worth going 750Ti.
Forgot to add, assuming your monitor is vga only since you mentioned 1030 with vga, Zotac is the only brand i know of that has vga on a 10 series card, the rest are all digital so if you were to consider a different card that had digital output only, an active converter hdmi - vga or dvi to vga can also work.
