Will a GTX 1050 fit inside a HP Elite 8200?
fakegaming80
So i just purchased a GTX 1050 and a HP Elite 8200, based off of many youtube videos it seems it does fit and work for them but i'd like to know a little more.
I want to know if it will fit inside and if it will work with the power supply provided with the computer.
I am a little worried due to the fact that i do not have any more money and it was my last bit of money for awhile while not knowing if it is going to 100% work or not.
https://www.amazon.com/gp/product/B01HSJ2O0Y
https://www.amazon.com/gp/product/B01MG0733A
Won't work, somewhat.
The SFF pc you purchased needs the Low profile version of the 1050 to have it so you can slose the side. The regular cards are too tall.
Some people install regular GPUs and leave the side cover off...
Low Profile 1050 only $123
Also remember that these cards do not have analog (VGA or DVI) output. They are digital only (DVI, HDMI, or Display Port depending on the exact card you get). If you need analog then you will need to purchase an active adapter or an older GPU. Active adapters are failry cheap now, many under $10.
Hope this helped.
Hope this helped.
