Will a GTX 1060 work and fit in my computer
BKay
6
Hello!
This is the PC I have: http://support.hp.com/us-en/document/c04343334
This is the GTX 1060 I want: https://www.amazon.co.uk/gp/product/B01IPFMVCQ/ref=s9_simh_gw_g147_i1_r?ie=UTF8&fpl=fresh&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=&pf_rd_r=Y12VEY57E6T5V5GYM5W2&pf_rd_t=36701&pf_rd_p=16f14aeb-bd11-4e9e-8c26-9ca0139074ee&pf_rd_i=desktop
I understand that there are other versions and such so if this 1060 does not fit, will a different fit in? or should I possibly look at a different card? Any thoughts and answers are appreciated, thanks.
You need to know your case GPU clearance, knowing that you can see if a GPU will fit or not, as for recommending you a card, i would avoid getting cards with that kind of cooler (aka blower fan) get a card with a custom cooler.
personally i WOULD recommend a blower card considering the lack of available airflow options in that HP case. that particular card on amazon is wayyyyyy overpriced though. there are extra small gtx 1060s out there intended for mini-itx systems so if you can't fit a blower style cooler that i can guarantee will fit
