Will a GTX 1070 work on this system?
Fazuras
14
Hi everyone,
Currently I am playing Battlefield 1/5 on Medium. I am able to spend a little bit of money on a new graphic card, because I am 'done' with the medium graphics, bad and sometimes unsharp images and lags.
Can I replace my GTX 960 by a GTX 1070 (and buy a sufficient power unit) to run Battlefield 5 on ultra? And will my motherboard be able to handle this?
I am asking, because I can spend ~500 euro on a new graphic card, but to buy a whole new PC goes a step too far to play a single game.
My system is:
Motherboard: P55-UD3
Intel core i7 CPU @ 2.80GHz
Memory: 8192MB RAM
Card name: NVIDIA GeForce GTX 960
Thanks guys for your help, answers will be appreciated.
For 1070, a quality 450W+ or higher PSU is recommended.
Your build supports a Titan V too just that your other components would bottleneck it.
As for BF1/5, I'm worried about your CPU. These games are very CPU intensive. While gaming, check your CPU usage with task manager. If it goes above 90%, you might need to upgrade it too.
Yes you could get the GTX 1070 and play on ultra and expect around 60fps due to your CPU being a bit slow because it's old. I would get the 1070 and then see if I wanted to start saving for a new CPU/Mobo/RAM.
Before you do that though, check your power supply. What PSU do you have?
I play BF1/5 at ultra at 1440p with a 980ti and 8gb of ram. its flawless.
Anything on the list:
https://uk.pcpartpicker.com/products/power-supply/#e=6,5,4&sort=-rating&page=1&W=450,800
Or tier 1,2 on this one.
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/
I recommend EVGA G2/3 or Corsair RMx/i. Good PSUs last a long time. Spend 100 euros if needed so it would work for 5+ years without problems.
https://uk.pcpartpicker.com/product/Rp8H99/corsair-power-supply-cp9020091na
https://uk.pcpartpicker.com/product/sMM323/evga-supernova-g3-550w-80-gold-certified-fully-modular-atx-power-supply-220-g3-0550
