Will a GTX 780ti fit in my PC?
OldWorld
136
Hi guys,
Ignoring the dust and poor wire placement, will a GTX 780ti fit in my PC? I heard the card was dual slots, what does that mean exactly? My tower is a mid, please see below for some images of my PC.
http://i.imgur.com/zy4YWPn.jpg
http://i.imgur.com/17ojqTQ.jpg
http://i.imgur.com/zGc9lXh.jpg
http://i.imgur.com/GQUrjKF.jpg
I fear the components are too close together. My heatsink is massive, and almost touches the side panel of the tower.
My current specs are:
AMD 7950 3GB
i5 2550k 3.4GHz (OC'd to 4.1)
8GB RAM DDR3
Gigabyte Z68MA-D2H-B3 Motherboard
Thanks in advance.
What is the brand and model of the GeForce GTX 780 Ti card?
Non-reference design cards have different lengths due to the different cooler designs being used.
What is the PSU brand and model (i.e. do you have enough power for the new graphics card)?
What is the brand and model of the computer case?
Thanks for the quick reply. In terms of slots, I read on Amazon that the 780ti uses (if I remember rightly) dual slots? What does that mean exactly? Would that infringe on the space? Does my computer have dual slots?
