https://forums.lenovo.com/t5/ThinkC...ideo-VR-Oculus-Passmark-benchmark/m-p/3357125My concern is the compatibility with my motherboard since Lenovo has a gpu whitelist
What PSU exactly? I need to know if you have the proper power connectors to power the card. But yes the card will fit.Corsair now dont worry about psu im frustrated about the compatibility with the gtx 960 2gb evga to be exact
I don't remember the name but it has 2 free 6 pins which i need only oneWhat PSU exactly? I need to know if you have the proper power connectors to power the card. But yes the card will fit.
My concern is the compatibility with my motherboard since Lenovo has a gpu whitelistWhat PSU exactly? I need to know if you have the proper power connectors to power the card. But yes the card will fit.
Okay I just wanted to make sure you had them.I don't remember the name but it has 2 free 6 pins which i need only one
What about compatibilityOkay I just wanted to make sure you had them.
Ohhh sorry didn't se that replyhttps://forums.lenovo.com/t5/ThinkC...ideo-VR-Oculus-Passmark-benchmark/m-p/3357125
Based on this Lenovo forum users have gotten the GTX 960 to work.
No worries and it should work.Ohhh sorry didn't se that reply
Yos and it only requires a 6pinNo worries and it should work.
Is the 960 you want have the one fan?
Just a quick question I've seen lots of m91p models with different cpus and different cases from small to full towers but is the motherboard the same for all m91p types ?Then you should have no problem about clearance as well.
They are different motherboards for each type of m91p because you have the USFF, SFF and the tower form factors.Just a quick question I've seen lots of m91p models with different cpus and different cases from small to full towers but is the motherboard the same for all m91p types ?
I meant compatibility wise are they all the same compatibility because I'm worried that m91p in the passmark was a different model mobo or something like thatThey are different motherboards for each type of m91p because you have the USFF, SFF and the tower form factors.
Holy shmuf thank you so muchNo they were using the tower because you cannot fit a GTX card inside the USSF or SFF.
Hello again so basically i bought the gtx 960 and test opened the pc to see if it's compatible and it did work with a screen saying plug the pcie 6pin connector but that's not the point what i mean is since the pc actually Booted with that card into the error screen doesbthat mean it's compatible or is it common for all cards and happens even to incompatible hardware?Your welcome!
Your welcome!
Btw about that Corsair psu i ordered it with the 960 didn't have at the time of the thread which is yesterday
Kinda confused about what your'e saying in general and about the PSU.Hello again so basically i bought the gtx 960 and test opened the pc to see if it's compatible and it did work with a screen saying plug the pcie 6pin connector but that's not the point what i mean is since the pc actually Booted with that card into the error screen doesbthat mean it's compatible or is it common for all cards and happens even to incompatible hardware?
Basically I don't have the Corsair psu at the moment but I've open tested my pc with the 960 (without connecting 6 pin) to see if it's compatible and it did boot but it says connect the pcie 6pin connector but my concern is that since it booted anyways and didn't get a black screen (even if i booted into an error screen) does that mean I've passed the compatibility test with the 960?Kinda confused about what your'e saying in general and about the PSU.
