Hello!
I'm looking to upgrade my graphics card from a GTX 560 Ti to a GTX 970 (This is the one I'm currently looking at buying).
I know that by moving some HDD's around I will be able to fit the card in the case I have (Nzxt hush). The problem is my motherboard, which is a MSI b75ma-p45 (image) which has the SATA-ports in a very weird spot. GTX 970 is a monster of a card and I think that it would cover the top four of these ports, of which I will (at least) have to use the 6 gb/s port.
To my question:
I want to use the 6gb/s SATA-port, which will most likely be covered by the card. Is this possible using an angled sata? Or will the port + cable rise too high, thereby making it impossible to use the SATA 6-gb/s? I did a quick measure and I think that the port + cable will "rise" from the card to a height of about 20 millimeters, in case that helps.
I understand if this is a hard one to answer, but I am kind of hoping that someone has been in my situation and it worked out
Thanks in advance!
To my question:
Thanks in advance!
