Will a GTX 970 work on my motherboard?
Jalen159
8
I run a 650w myself. Everything looks good other than its a bronze. If its the best you can afford it will work fine.
Sooo, the motherboard is fine?
This is it: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128602&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-AMD+Motherboards-_-N82E16813128602&gclid=CKbIyLat0cMCFZSPfgodrIQAow&gclsrc=aw.ds
Sure is. Best of luck to you! I run a 970 with a 8350 on a 970 chipset. Although I would reccomend going to a 990
Phew, thanks for the information, I had already ordered it before I asked this question and I did some research before and concluded that they would work, but I starting having doubts and got really worried. Thanks!
