Ooo, thank you... absolutely I am finding a reliable one, I didn't buy that psu yet. but I will be looking for another if it doesn't match that graphic cardHere you can see, from JG himself, that PSU is a POS. So no, it's not good enough for that graphics card and to be honest, if you just got this PSU you would be VERY wise to immediately return it and try to source something that is actually reliable and can supply the rated wattage, which that unit CANNOT.
Is the Huntkey Gs550 Psu any good ?
Hello everyone. Im going to build my very first pc and i am on a very tight budget the only new psu that i could fit in my budget was A Huntkey Gs550 Pc Specs : Intel i3-9100F Asus Nvidia GTX 1650 Super Tuf G.SKILL Ripjaws V Series 8GB DDR4 2800Mhz WD Green 500gb HDD ASUS PRIME Intel B365M A Woul...linustechtips.com
https://forums.tomshardware.com/threads/good-psu.3662366/#post-22061619Ooo, thank you... absolutely I am finding a reliable one, I didn't buy that psu yet. but I will be looking for another if it doesn't match that graphic card
how about that psu and its PCI?
https://citycenter.jo/gaming/gaming-power-supply/deepcool-de-600-v2-600w-high-efficiency-gaming-power-supply
Yeah, you don't want that unit either. As Jon said, both are garbage.Ooo, thank you... absolutely I am finding a reliable one, I didn't buy that psu yet. but I will be looking for another if it doesn't match that graphic card
