Will a Hyper 212 EVO fit with a Gigabyte GA-990FXA-UD3 and G.Skill Ripjaws X?
Xenocider
4
I've heard mixed reviews on if the Hyper 212 EVO will be able to fit with a Gigabyte GA-990FXA-UD3 and 2 G.Skill Ripjaws X Series (2x4GB). The ram has fairly tall heat spreaders so I'm worried that the cooler will block the ram. Has anyone built a computer using these parts?
If you use slots 2 & 4 rather than 1 & 3 it should work fine.
Does it fit in your case?
