will a i7-4790K work with a gtx 750
starflexthe2nd
23
i maybe will get a gtx 750 and if i do can i put it in my computer? i need to know if if its worth the shipping costs. please let me know and will it work with a 500W power supply.
my computer specs
i7 4790k
no grachics card at the moment
1 SSD 223 GB windows edition
1 WD BLUE HHD 1 TB
idk what motherboard but it dose handle a gtx 750
and i plug in 2-4 USB ports in normally 2!
I doubt you have that i7 and yet don't have the pci-ex slot the videocard requires. So as long as the 750 you're getting doesn't require a pci-ex connector that your power supply doesn't have, it should work fine. The GTX 750s usually don't require those connectors.
I assume you know the 750 Ti was the entry level gaming card, it was faster than the 750. So I hope your expectations aren't too high as far as game performance is concerned. It IS better than having no videocard, that's for sure.
depends on your case size
and if your motherboard has a pcie slot
plus the power supply having the proper pcie power cables
the 750 is obsolete with the rx 460 and gtx 1050 around
i will get a better card but i cant afford it yet :/ so i am asking if it will work but thanks for telling me!
i know :/ i am not that high but the price of those cards are way to high i am just looking for a grachis card that will work because i am sick of having no grachis card i get 70 fps on minecraft :/
