Hello,
I have two monitors now:
1. ASUS 27" MX27AQ 27" WQHD 2560x1440 IPS (60Hz)
2. ASUS VG248QE 24" Full HD 1920x1080 144Hz 1ms HDMI Gaming Monitor
I have an i7 7700K processor, and an NVIDIA GTX 1080 (not Ti) GPU.
I normally play War Thunder and PUBG on the 27" which runs at about 70 FPS with the graphics settings i like but the image is not as good as i thought it would be - even at 1440.
When I switch to the smaller 144Hz monitor I get about 120 FPS and the picture is smooth and detailed. But I really like the larger screen monitor.
So question: If I buy a 27", 2560x1440, 144Hz monitor, will my frame rate be reduced to the point where it was a bad decision, and nothing is gained? Do i need a better GPU, like the 1080 Ti then?
I thought the 1080 would get me better FPS on the 27", but there is one important ingame graphics setting (SSAA 4X) that really improves screen image detail - needed to spot enemy tanks at distance. but again, when I tick that choice, FPS goes from 170 to about 70. And it's still not as smooth as the 144Hz monitor.
Any other suggestions / thoughts?
Thanks!!
Thanks!!
