Will a "MSI GAMING GeForce GTX 1060 6GB GDDR5" be compatible with my current build?
Drakono
4
Will a "MSI GAMING GeForce GTX 1060 6GB GDDR5" be compatible with my current pc build? (One I'm looking to purchase to replace an overheating R9 290x.)
Gigabyte Z87 LGA 1150 BigFoot LAN Micro ATX Motherboard
XFX PRO 850W Black Edition Single Rail Power Supply
Corsair Hydro Series Extreme Performance Liquid CPU Cooler H80i
Corsair Graphite Series Black 600T Mid-Tower Computer Case (CC600TM)
Corsair Vengeance Pro 32GB (4x8GB) DDR3 1600 MHz (PC3 12800) Desktop
Intel Core i7-4770 Quad-Core Desktop Processor 3.4 GHZ LGA 1150 8 MB Cache BX80646I74770
My friend helped me build this pc, and being that I don't know too much I thought I'd just list everything. Sorry if it's a too little or not enough information. Thanks for your time.
Yes it will your Power Supply is sufficient, Motherboard is compatible (almost any would be) and you have enough room in your case. It's a very nice build good luck with the upgrade! Hope this helps :)
It helps tremendously! I was guessing it would work fine, but I really needed that second opinion considering my lack of knowledge. Thanks again for such a quick reply, and thanks for complimenting my build. It's nice to know it's at least still somewhat relevant after a couple years. I really appreciate the help. :)
