Will a MSI GeForce GTX 1060 GAMING X 6G fit and run with my system?
Matthew 81
I was wondering if my case would fit the MSI GeForce GTX 1060 GAMING X 6G and if my motherboard would also be compatible.
Current specs:
- MSI Z97 PC MATE
- Cyberpower X-Sentinel mid size tower
Assuming you have an adequate power supply it should work just fine. But will it fit physically? I can't find the case online. Measure from where you screw in the GPU to the HDD cage. MSI 1060 is 10.91" long.
they sell that case with full sized cards. so it should fit assuming the psu is good enough for it. it's a low powered card so should be good enough with stock psu, but look at it's specs to be sure and make sure it has the 8-pin power connectin the card needs
