Will a Nvidia gtx 1080 TI fit in my pc and what do I need to upgrade for it to work
Henry_102
27
As you see by the title I need to buy a 1080 TI and don't now if it's compatible so can someone tell me which model is best for mine and if it will fit
Thanks here are the specs of my PC
Power supply: Corsair CX-600 V3 Power Supply
Case: Aerocool Strike-X Advance Devil Red
Ram: Corsair Vengeance LPX CMK8GX4M2A2133C13R 8GB (2x4GB) DDR4 Red
Current card: Gigabyte GeForce GTX 1050 Ti G1 Gaming 4GB
Motherboard: ASRock Fatal1ty E3V5 Performance Motherboard
Processor: Intel Core i5 6600
Thanks everyone the help will greatly be appreciated
You can get a 1080Ti but you need to make sure that it is no larger than 290mm (there are many options, mainly depends on where you are buying from). Also another thing which I would change would be the Power Supply, it's a low quality one and you don't want to use such a PSU for a 1080ti (in my opinion).
thanks buddy
I am buying it this week which one should i get out of these two:
-Gigabyte GeForce GTX 1080 Ti AORUS Xtreme Edition 11GB
-ASUS ROG Strix GeForce GTX 1080 Ti OC 11GB
