Will a PAL DVCAM tape work in a NTSC DVCAM carmera?
G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
I've done some searching and haven't found a definitive answer to
this. I have a Sony PD150 Dvcam camera and I would like to get some
footage off of some PAL Dvcam tapes via firewire. Is this do-able at
all? Thanks
G
Guest
Guest
"woodface" wrote...
> answer to this. I have a Sony PD150 Dvcam camera and
> I would like to get some footage off of some PAL Dvcam
> tapes via firewire. Is this do-able at all? Thanks
Some equipment will play and/or record in both standards.
Unless the equipment SPECIFICALLY states that it does
both PAL and NTSC, it is safe to assume that it won't.
Dual-standard is a desirable feature and you can be sure
that equipment makers that have it will flaunt it.
For example the Sony DSR-11 does both PAL and NTSC.
G
Guest
Guest
is it a PAL camera?
"woodface" <here@there.com> wrote in message
news:6tq1e0lmq5qirv04g57kvq4gl2v2d6poki@4ax.com...
> all? Thanks
G
Guest
Guest
On Tue, 29 Jun 2004 04:26:21 GMT, "nappy" <no_spam_@sorry.com> wrote:
>is it a PAL camera?
Not according to the subject...
Chris Pollard
CG Internet café, Tagum City, Philippines
http://www.cginternet.net
G
Guest
Guest
"Richard Crowley" <rcrowley7@xprt.net> wrote:
>"woodface" wrote...
I was thinking, even if it is an NTSC camera, the firewire is just a
file transfer, so it is maybe possible? Unless of course the camera
recognises it as a PAL tape and rejects it.
Doubt that it could hurt anything to try anyway.
Cheers
Kevin Gleeson
Blue Rocket Productions
www.blue-rocket.com.au
www.hoota-snoz.com
G
Guest
Guest
"Kevin Gleeson" wrote in message
Or more likely doesn't recognize an NTSC pattern and
rejects the tape. NTSC and PAL video are encoded
differently in DV and written differently on the tape
(like a different tape speed, etc.)
Don't get your hopes up.
G
Guest
Guest
Oh... really?
I thought a bit of logic might be helpful.
He answered his question in his post.
"Christopher Pollard" <rubbish@cginternet.net> wrote in message
news:eek:vs1e0t1gp9bpcdc182hthbmbclqco722t@4ax.com...
> >is it a PAL camera?
> Chris Pollard
Brian
1,371
>all? Thanks
Most video editors will accept either PAL or NTSC video.
Regards Brian
