U upgrademyoldpc Reputable Aug 2, 2015 5 0 4,510 Aug 2, 2015 #1 This is the desktop - http://www.newegg.com/Product/Product.aspx?Item=N82E16883113100 This is the GPU - http://goo.gl/1rSVom
Solution Brandon- Aug 2, 2015 upgrademyoldpc : Brandon- : upgrademyoldpc : This is the desktop - http://www.newegg.com/Product/Product.aspx?Item=N82E16883113100 This is the GPU - http://goo.gl/1rSVom Yes sir, both are compatible with each other. Do you think the 220w power supply can support this http://www.amazon.com/dp/B004I5UDO6/ref=psdc_284822_t1_B004X8EO6Q? Yes, that Power Supply will support that Video card.
Brandon- Reputable Aug 1, 2015 322 0 4,960 Aug 2, 2015 #2 upgrademyoldpc : This is the desktop - http://www.newegg.com/Product/Product.aspx?Item=N82E16883113100 This is the GPU - http://goo.gl/1rSVom Yes sir, both are compatible with each other. Upvote 1 Downvote
U upgrademyoldpc Reputable Aug 2, 2015 5 0 4,510 Aug 2, 2015 #3 Brandon- : upgrademyoldpc : This is the desktop - http://www.newegg.com/Product/Product.aspx?Item=N82E16883113100 This is the GPU - http://goo.gl/1rSVom Yes sir, both are compatible with each other. Do you think the 220w power supply can support this http://www.amazon.com/dp/B004I5UDO6/ref=psdc_284822_t1_B004X8EO6Q? Upvote 0 Downvote
Brandon- Reputable Aug 1, 2015 322 0 4,960 Aug 2, 2015 Solution #4 upgrademyoldpc : Brandon- : upgrademyoldpc : This is the desktop - http://www.newegg.com/Product/Product.aspx?Item=N82E16883113100 This is the GPU - http://goo.gl/1rSVom Yes sir, both are compatible with each other. Do you think the 220w power supply can support this http://www.amazon.com/dp/B004I5UDO6/ref=psdc_284822_t1_B004X8EO6Q? Yes, that Power Supply will support that Video card. Upvote 0 Downvote Solution
U upgrademyoldpc Reputable Aug 2, 2015 5 0 4,510 Aug 2, 2015 #5 Brandon- : upgrademyoldpc : Brandon- : upgrademyoldpc : This is the desktop - http://www.newegg.com/Product/Product.aspx?Item=N82E16883113100 This is the GPU - http://goo.gl/1rSVom Yes sir, both are compatible with each other. Do you think the 220w power supply can support this http://www.amazon.com/dp/B004I5UDO6/ref=psdc_284822_t1_B004X8EO6Q? Yes, that Power Supply will support that Video card. There will be no issues with insufficient power, etc.? Upvote 0 Downvote
Brandon- Reputable Aug 1, 2015 322 0 4,960 Aug 2, 2015 #6 upgrademyoldpc : Brandon- : upgrademyoldpc : Brandon- : upgrademyoldpc : This is the desktop - http://www.newegg.com/Product/Product.aspx?Item=N82E16883113100 This is the GPU - http://goo.gl/1rSVom Yes sir, both are compatible with each other. Do you think the 220w power supply can support this http://www.amazon.com/dp/B004I5UDO6/ref=psdc_284822_t1_B004X8EO6Q? Yes, that Power Supply will support that Video card. There will be no issues with insufficient power, etc.? Nope, you're good! Upvote 0 Downvote
U upgrademyoldpc Reputable Aug 2, 2015 5 0 4,510 Aug 2, 2015 #7 Brandon- : upgrademyoldpc : Brandon- : upgrademyoldpc : Brandon- : upgrademyoldpc : This is the desktop - http://www.newegg.com/Product/Product.aspx?Item=N82E16883113100 This is the GPU - http://goo.gl/1rSVom Yes sir, both are compatible with each other. Do you think the 220w power supply can support this http://www.amazon.com/dp/B004I5UDO6/ref=psdc_284822_t1_B004X8EO6Q? Yes, that Power Supply will support that Video card. There will be no issues with insufficient power, etc.? Nope, you're good! Thank you! Upvote 0 Downvote
Tradesman1 Legenda in Aeternum Jun 5, 2013 67,881 41 126,960 Aug 3, 2015 #8 The nVidia calls for a minimum of a 300 watt PSU, if your Gateway has a 22 PSU it's prob less than 200 on the 12 volt rail that powers the GPU Upvote 0 Downvote
