jbrown156 Reputable May 7, 2014 1,498 0 5,960 May 7, 2014 #1 i just bought a computer which apparently has a 1.1 slot and i want to know if it will work or it will slow down due to bandwidth restrictions. also can someone tell me what generation of pci e does a asrock g41m vs3 r2.0 motherboard has ?
Solution Danbuscus25 May 7, 2014 your mobo has 1 pcie x16 gen 1 slot, so yes it will limit the bandwidth of a 2.1 card, however the performance hit will likely be less than ~3%.
Danbuscus25 Dignified Feb 15, 2014 5,368 0 13,960 May 7, 2014 Solution #2 your mobo has 1 pcie x16 gen 1 slot, so yes it will limit the bandwidth of a 2.1 card, however the performance hit will likely be less than ~3%. Upvote 0 Downvote Solution
B bazanella Honorable Oct 1, 2013 9 0 10,520 May 7, 2014 #3 It will work yes. All new pci-e are backwards compatible Upvote 0 Downvote
jbrown156 Reputable May 7, 2014 1,498 0 5,960 May 7, 2014 #4 Danbuscus25 : your mobo has 1 pcie x16 gen 1 slot, so yes it will limit the bandwidth of a 2.1 card, however the performance hit will likely be less than ~3%. So will games play smoothly ? will games like fifa 14 play if i install a good card ? ( inno3d geforce gt 440 2gb in specific) Upvote 0 Downvote
Danbuscus25 Dignified Feb 15, 2014 5,368 0 13,960 May 7, 2014 #5 well, it depends on your specs, but the older pcie x16 slot will not make a game go from playable to unplayable. Upvote 0 Downvote
jbrown156 Reputable May 7, 2014 1,498 0 5,960 May 7, 2014 #6 Danbuscus25 : well, it depends on your specs, but the older pcie x16 slot will not make a game go from playable to unplayable. I a asrock g41m vs3 r2.0 motherboard 2gb dd3 ram pentium 4 3.0ghz (630) how will that fair against games like fifa 14 with graphics card mention earlier ? Upvote 0 Downvote
Danbuscus25 Dignified Feb 15, 2014 5,368 0 13,960 May 7, 2014 #7 eh, im not sure because i dont know that game, but dont expect too much from a 440 and pentium 4. Upvote 0 Downvote
jbrown156 Reputable May 7, 2014 1,498 0 5,960 May 7, 2014 #8 Danbuscus25 : eh, im not sure because i dont know that game, but dont expect too much from a 440 and pentium 4. ok what about games like call of duty mw 2 ? will that play ? Upvote 0 Downvote
Danbuscus25 Dignified Feb 15, 2014 5,368 0 13,960 May 7, 2014 #9 yes, but with low-medium settings, depending on the resolution. Upvote 0 Downvote
