E eduzit63 Honorable Dec 19, 2012 7 0 10,510 Dec 19, 2012 #1 Will a Phenom II x 6 Cooling Fan work for an FX 6100 Processor?
R Ramzzz2936 Honorable Nov 25, 2012 163 0 10,690 Dec 19, 2012 #2 u should check the coolers manufactires site there are all the details all the processors u can use the cooler on Upvote 0 Downvote
popatim Titan Moderator Dec 2, 2009 39,308 1,099 136,890 Dec 19, 2012 #3 I beleive most of the p2x6's were 125w (not sure about the 1045t) and the fx6100 is a 95w part so yes the cooler will work fine. Upvote 0 Downvote
E eduzit63 Honorable Dec 19, 2012 7 0 10,510 Dec 19, 2012 #4 popatim : I beleive most of the p2x6's were 125w (not sure about the 1045t) and the fx6100 is a 95w part so yes the cooler will work fine. Yeah this CPU Cooling Fan is from a PX6 1100? Upvote 0 Downvote
B Brett928S2 Champion BANNED Jan 3, 2012 15,313 1 52,960 Dec 19, 2012 #6 Hi Yes and it will probably cool the cpu better... All the best Brett Upvote 0 Downvote
Z1NONLY Distinguished Jan 13, 2012 2,223 1 20,465 Dec 20, 2012 #7 It will work better than a 6100's stock cooler. (And it will fit) The only thing you don't want to do is install a 95w cooling solution on a 125w CPU. -But using a 125W cooler on a 95w chip is actually an upgrade. Upvote 0 Downvote
