Will a r9 290x work with a corsair cx600m?
BeatboxingFTW
46
Hello i wanted to know if a r9 290x would work with a corsair cx600m if not will it hold for a second msi r9 270x? My specs:
Amd a10-7850k oc @ 4.5ghz, 4gb ram 1600mhz, msi r9 270x, gigabyte ga f2a88xds2. Thanks
The CX600m will work, but you won't have much headroom left with that 300W gfx card. And yes, there will be noticeable CPU bottle neck in CPU limited games and on busy 64 player servers with the APU. Not a deal breaker, but enough that you would end up getting the same gaming results with a less expensive card. R9-280/280X
OC the APU as much as you can to help.
Uhh I would upgrade your cpu... It would be a severe bottleneck for your system if you go to a 290x.
But to answer your question, yes you should be fine with the cx600. Crossfiring another 270x would probably consume more power.
Pls dont even say anything about bottleneck if there were actually some there will be about 3fps hit so pls dont
LOL are you serious right now? Probably depends on what games you are playing, but in cpu intensive games you would see a sizeable drop on fps. Sorry to burst your bubble but the A10-7850k is actually a pretty weak cpu.
And heres benchmarks to back up my claim: http://www.extremetech.com/gaming/177677-dual-graphics-dud-intel-clobbers-amds-apus-in-budget-gaming/2
This test was done with a Amd R7 260x. You see a difference of 9 fps on metro last light. With a 290x you will see a much bigger difference.
Dude i know that my cpu is SUPER weak but not to the point of a 1.5ghz intel core i3 for example i knew that that intel u are showing is way better but i couldnt afford it at the time so pls i know it will bottleneck but it wouldnt be severe thats what im saying plus i problably will buy a amd athlon 860k i think that the name which is the fastest cpu for fm2+ because i dont wanna buy a new motherboard
Well alright thanks for the help but keep in mind my pc build is somewhat complete since i still need 8gb of ram and i slowly upgrade my pc until i feel is good enough since i started without a gpu and now im with a r9 270x maybe one day ill go to am3+ and maybe get 29 gtx titans (lol not possible)
