Will a Radeon 3850 work with a 230 watt PSU?
Zynox
Can i use a radeon 3850 or a Radeon 3650 with a 230 watt PSU?
If i can't use the PSU that I'm using now, can someone tell me which I can buy?
Motherboard: FSB 800 Mhz, AGP 8x
CPU: Intel P4 3,2 Ghz Hyper Threading
Cashe: 512 KB
RAM memory: 2 st 256 MB, 1 st 1024 MB, 400 Mhz
Graphic card: I'm currently usning a ATI Radeon 9800 256 MB.
ATI Radeon HD 3870 and ATI Radeon HD 3850 System Requirements
450 Watt or greater power supply with 75 Watt 6-pin PCI Express® power connector recommended (550 Watt and two 6-pin connectors for dual ATI CrossFireX™)
http://ati.amd.com/products/Radeonhd3800/requirements.html
Look into a QUALITY 450w+ Corsair, PCP&C, Seasonic, Enermax or Antec Earthwatts PSU.
You can generally find one of the above for less than $50 on newegg.
I have a compaq presario 6016us that comes with a 220W power supply. other installed components are 1 sata card, 1 wd green drive 1tb, 1 cd/dvd burner, and 1gb mem.
I bought the Sapphire 3850. I have been running for a month or so fully stable. It comes with a Molex to 8pin P8 adapter with 2 molex connectors which I was careful to run two different lines coming from the power supply. There are several web sites that indicate that the maximum wattage for this card is right around 70 watts. http://www.xbitlabs.com/articles/video/display/gigabyte-radeonhd3870-3850_5.html#sect0
