Will a Radeon 6670 work?
my budget is around 150ish.
i would prefer to buy from ebay or amazon
PCPartPicker part list: http://pcpartpicker.com/p/AT1X
Price breakdown by merchant: http://pcpartpicker.com/p/AT1X/by_merchant/
Benchmarks: http://pcpartpicker.com/p/AT1X/benchmarks/
Video Card: HIS Radeon HD 7770 1GB Video Card ($99.99 @ Newegg)
Power Supply: Corsair Builder 430W 80 PLUS Bronze Certified ATX12V Power Supply ($24.99 @ Newegg)
Total: $124.98
(Generated by PCPartPicker 2013-03-06 15:18 EST-0500)
Or
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026 and
http://www.tomshardware.com/forum/105654-8-7750hd-asrock-microatx-fx4100 (used 7750 for $70 is a good deal on here)
That is an inefficient, poor-quality PSU. You can get a modern, efficient (despite not being 80+) Antec VP-450 for around the same price.
The video card also has two problems, although that may be why it's cheap. First of all, it's a Diamond; one of the few companies on my personal "Do Not Buy" list, in this case for bugs, miserable support, and general incompetence. Second, it's got DDR3, which is a lot slower than GDDR5.
With a budget of $150, you should be able to get an Antec VP-450 and a GDDR5 version of the HD7750 at the least; possibly a HD7770 (although shipping will likely push over your budget a little).
Edit: LarryM has posted one such inexpensive HD7770, but note that price is after MIR, which is a game you may not win. Still, it's only $110 before MIR.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161402
what about this one?
For the same $40 (MIRs are a game; I don't count them), I'd personally choose this Antec VP-450: http://www.newegg.com/Product/Product.aspx?Item=N82E16817371045
That's because the Corsair "Builder," while not a junk PSU, was built by CWT, not Seasonic (which builds the higher-end Corsairs), using some inferior Samxon capacitors from their "GF" line that are known to die early. The Antec is made by FSP, and is efficient enough for 80+ but is disqualified for not having active PFC.
Edit: http://www.hardwaresecrets.com/article/Antec-VP450-Power-Supply-Review/1487/11
