Will a Radeon R7 250 be compatible with my computer??
NavE3n
43
My system config is:
HP pavilion(desktop)
Intel Core 2 Duo.
4GB RAM.
Windows 7 64-bit.
500GB HDD.
450w SMPS.
So will i be able to install this graphics card?
also im confused between the R7 250 and Nvidia GeForce GT 640 2GB. so which one is better?
i play games like batman, assasin's creed,crysis, FIFA-14,Battlefield,sleeping dogs etc 😛
Also im confused with my SMPS, the R7 requires a 400w power supply, ao which smps do i buy? im a little low on budget 😛 so i was thinking a Zebronic.
http://www.flipkart.com/zebronic-zeb-450w-450-watts-psu/p/itmdkquvsccg3z3q?pid=PSUDKQUHKGRASFKN&otracker=from-search&srno=t_1&query=smps&ref=7a9ddf6d-7b0d-47c2-9a93-ebabea5d5691.
is that any good?
Thanks in Advance! :)
What is the make/model of your newly bought PSU ?
If you have another PCI-E slot on your MB then try that slot, or try the GPU on another PC. See what happens.
There could be several reasons for GPU fan not spinning: 1. The PSU not providing enough power to PCI-E slot. 2. The PCI-E slot/s are faulty. 3. The GPU itself is faulty. 4. GPU not properly fitted into slot. 5. You may need to update the MB BIOS for proper function of GPU, it could be the MB is not seeing the GPU as an external display device.
You can try the clear CMOS method also, by removing the CMOS battery for five minutes, it will set the BIOS to its default.
If everything fails to run the GPU, then RMA would be the last resort.
Go with R7 250, it consumes 75W max on full load, so your PSU can handle the GPU, no need to replace it.
HD 7750 is also another great option, bit fast than R7 250, and requires same amount of power.
I think your PSU has no 6 pin PCI-E connector, so don't think of HD 7770 or 7790, they will need 6 pin peg connector.
And if you want to buy a SMPS/PSU don't buy your chosen one, rather go with CX 430W(good one) or 500W(budget one) of Corsair, not the best but will do for you.
I currently own a 240w SMPS! thats why i'd like to buy a better one! And thanks for your Answer!
The SMPS is not good. Even if ur smps is a high quality one, it cannot handle the hd 6670. If u go for a graphics card more than the hd 6670, the performance would decrease as the processor is old and weak. Buy a 400 watt smps or more. The Zebronic u listed will support the hd 6670 but its life time will be only for a year. If thats ok then buy the zebronic
So what is your budget for PSU and GPU ?
Hi lonewolf!
i bought the R7 250 and a 450w PSU. after i installed all the drivers, and connected my VGA cable to the GPU s slot. the monitor still is in sleep mode! and when i opened the cabin, the fan in the GPU wasnt spinning! 🙁
what is the problem?? 🙁
It is a zebronic 450w pcu. the gold series one.
a lot of people are talking bout 6-pin buses and crap, i really dont understand that !! 🙁 is it cause of that??
no,no. there is no such connectors on my GPU. I'm supposed to just plug the GPU onto my mobo, install the drivers and play! :/ what do i do? 🙁
Yes that is how it should work generally. Try another PSU to test.
Frankly this is the problem with branded PC's, the BIOS being locked for an upgrade, and I think this is the real issue you are having now. Anyways try the methods I mentioned earlier, and try to upgrade the BIOS of MB, might work for you. Good luck.
Thank you so much for patiently answering me! appreciate it! :)
yeah its worth a try! i'll get back to you after i try it all! Thanks again :) and btw can i check it with my old psu? (240w) will it work? or i guess not? cuz in the amd website,it clearly states that the card requires 400w
you can safely purchase R7 250 , im using power colour r7 250 , its working fine i have purchased last week my psu is umax 450 w ,
purchase & feel the diff and enjoy the colours
