yeah, plugged it in with hdmi and dvi, and the bios thing i tried that, but mines doesn't seem to have that option to change anything in bios like that link you shared
That PSU is crap and is not safe for the PC. It is VERY terrible quality. Change for an Antec, XFX, Seasonic, EVGA (G2,B2,GS). This is the single most important part of the computer. A bad PSU and the whole PC will be toast.
Also, do you have the 6-pin power connector connected from the PSU to the GPU?
no, ment i tried both hdmi and dvi, but not at same time, and yes it has the poer connected to the gpu, the fans on card work, just won't boot up, just power on, no sign of anything starting normally.
okay tried it again, when i press f2 and go into bio's there is a tab that says boot, but under it, it lists 5 things, hard drive, cd drive, usb, and usb floppy, and network, and if you try and change it, it will only let you change it to one that i've of the names i listed
dang, from what i can see after you said it was in bios, i looked at some vids, i can see how they change theres, but mines won't let me do that kind of stuff, dunno why
