B ben4594 Prominent Dec 29, 2017 24 0 510 Dec 29, 2017 #1 WIll a RADEON r9 290 gpu work with a MSI 760GM-P23 motherboard? Need help please!
Solution COLGeek Dec 29, 2017 It should work as long as your power supply is sufficient to power the system and you have enough physical space to install it.
COLGeek Cybernaut Moderator Apr 6, 2009 60,043 5,526 184,340 Dec 29, 2017 Solution #2 It should work as long as your power supply is sufficient to power the system and you have enough physical space to install it. Upvote 0 Downvote Solution
COLGeek Cybernaut Moderator Apr 6, 2009 60,043 5,526 184,340 Dec 29, 2017 #4 You are welcome. Upvote 0 Downvote
