P Puchai Reputable Nov 29, 2015 1 0 4,510 Nov 29, 2015 #1 Hi so I'm looking to upgrading my GPU to a Sapphire Nitro r9 390, however I'm worried that the Sapphire Nitro r9 390 fit inside my case. If not what other r9 390 brands would you recommend?
Solution clutchc Nov 29, 2015 According to the case's specs, the longest card that will fit is 290mm: http://www.corsair.com/en-us/graphite-series-380t-portable-mini-itx-case According to the gfx card's specs, the card is 308mm long: http://www.sapphiretech.com/productdetial.asp?pid=C436E37C-8A09-48B6-9F2B-F4AF86E377B6&lang=eng See how easy that is? Find a different card and check its specs.
clutchc Titan Apr 22, 2009 43,160 409 131,790 Nov 29, 2015 Solution #2 According to the case's specs, the longest card that will fit is 290mm: http://www.corsair.com/en-us/graphite-series-380t-portable-mini-itx-case According to the gfx card's specs, the card is 308mm long: http://www.sapphiretech.com/productdetial.asp?pid=C436E37C-8A09-48B6-9F2B-F4AF86E377B6&lang=eng See how easy that is? Find a different card and check its specs. Upvote 0 Downvote Solution
