Will a Soundcard help me out?!, Audio is messed up and microphone is not working. HELP!
Mads Haugaard
246
Hey! I need some help with some stuff. Ive recently got a problem with my computer. It's not picking up any "Voice" sounds.
GEAR information:
"Razer Blackshark" (Headphones)
Specs on Headphones:
[Sound Specs]
Drivers: 40mm neodymium magnets with copper-clad aluminum voice coil.
Frequency response: 20Hz – 20KHz.
Impedance: 29 O.
Sensitivity @ 1KHz: 105dB ± 3 dB.
Input power: 50mW.
Cable: 1.3m rubber sheathed.
Connector: 3.5 mm audio + mic combined jack.
[Microphone]
Frequency response: 50Hz – 16KHz.
Signal-to-noise ratio: 50dB.
Sensitivity @ 1KHz: -37 dB +/- 4dB.
Pick-up pattern: Unidirectional.
[Software / Drivers]
I'm using Razer synapes (Program)
And Realtek HD Audio config.
[Other information]
So, my headset has 1 cable that is a "Multi-Jackstick?" Wich goes into a Jackstick splitter.
They are plugged into the MB, i'm using the MSI X99 SLI +.
And i have updated everthing.
[Things i have tried]
Controlpanel -> Hardware and Audio/Sound -> Audio/sound -> Microphone, messed with alot of settings.
So what i find wierd is that the jacks on top of my case works but they are not good.
Also i checked BIOS if "Onboard sound" was Enable and it was.
[THE ISSUE / PROBLEM]
1)Friends can hear most of my games/videos but they can't hear me. (Using skype)
And i have checked skype if some settings were "Fucked-up". But no. Everything was as normal and standard.
I have tried using my Headphones on another PC wich worked after i changed the input and all worked fine there. But on my Gaming rig it won't work.
[Can this solve it?]
1) Buy a Soundcard?
If so wich one?
i have this one in mind ("ASUS Xonar DGX")
2) Special Software / Setup-program?
Is there ANY Software that can Detect and Solve this problem?
PLEASE HELP!.. Thanks for reading my shtting long Post.
Hey, thanks for reading my damn long post :d. But yes, i have tried to "Reset to default". But nothing happends.
I can get my mic to work. But it only lasts for 10 mins or so. It's like when i De-activate the Sound effects like "Noise cancling" and stuff like that. But it goes off again after some time.
Yes, i have updated my drivers.
BUT Would a soundcard Fix it 100% ?
Yes, i have tried that.
But i can get my Sound to work but not the mic, so what i have tried too is by using 2 splitters. like..
Headphones go into a splitter.. One of the Jacks is plugged to front of my case (mic) and then i use another spillter to extend the green jackstick to the back for better audio.
Sounds wierd right?
Works for 10 mins and then it stops.
I think i fixed it..
I had ALOT of Audio drivers installed and active.
One of them was a "Sound board" Driver. I uninstalled that driver and right now it works, i'm gonna see if it last forever tho.
