Will a Thermalright IFX-14 Fit Inside Antec 900 Ultimate Gamer Case?
Noobster15
176
Found a good deal for the ThermalRight IFX-14 Inferno and wondering if it will fit inside my Antec 900 Ultimate Gamer case.
Intel Core 2 Duo 8400 Currently OCed to 3.4GHZ on stock cooling, would like to get it up in the 4ghz+ range
Conumdrum
2,397
Should..... The amount you need to cut off the fan or heatsink would be a very very small amount. And the side fan really helps airflow. So get a side fan later if ya want.
What you should do is measure the top of the CPU chip to the edge of the case. Then go to the Thermalright web page and look up the dimentions for that cooler.
You'd have your own answer then, and be sure.
Noobster15
176
Yes, well im not really worried about the 2 large heatsinks
im worried about the heatsink coming from the back of the Mobo the small one
Im wondering if THAT will be able to fit
overshocked
1,999
I dont think it goes out much further than the cpu cooler does.
check it out...
it should fit ( ;
Noobster15
176
Ah thank you very much
Also from your picture its seems that you had to make the fans face downwards... were you unable to rotate the heatsink without it covering RAM slots?
