will a UPS help
TIan__
22
once every few weeks my pc will freeze and reboot randomly without BSOD, had a 1250W psu and the total watt usage of my pc is 400W under load, done all testing and pass,
the only thing i had yet to do is change my psu which i dont have a 2nd spare, isolate pc power which is impossible ( 1 plug only in my room)
( this happen after i had my audio system install dac+amp and speaker, also a electric heater plugged into belkin 8 outlet surge protector and use a total of 900W)
Will a ups dedicated to my pc help ?
The eaton ellipse pro 1200va 750w isn't one I can make a suggestion on as mostly its only got french reviews. It does seem to have a fair user rating on Amazon so that is something.
https://www.amazon.fr/Eaton-Ellipse-1200-Onduleur-pour/dp/B00D13RE3O
I can tell you the tripp lite is a good product but is a bit on the high side.
https://www.amazon.fr/dp/B00G1VFCRI/?tag=pcp09-21
The best APC I think is the BR1200GI for the price. It has a 30min run time on half voltage and about 10mins on full load. Thing is tho the price is pretty high.
https://www.amazon.fr/dp/B0049CWKY4/?tag=pcp09-21
Wow price is crazy on even the low end power versions. The tripp lite may be the best best choice for the price but that is high.
UPS: CyberPower CP750LCD UPS (€195.90 @ Amazon France)
Total: €195.90
Generated by PCPartPicker 2017-01-04 02:14 CET+0100
or
UPS: Tripp Lite SMX1500LCDT UPS (€250.00 @ Amazon France)
Total: €250.00
Generated by PCPartPicker 2017-01-04 02:15 CET+0100
The cyberpower unit seem to be 120v unit which wont work on france who uses 230v
For now i am looking at eaton ellipse pro 1200va 750w, as for APC it seem that their product wasn't as good as in the past
Any other recommendations?
