Will a video card fit my case? and how to know what power source to get?
JRC2307
i'm planning to get a Case corsair vengeance C70 or a graphite 230t compact, with a intel i7 4770k a video card evga nvidia gtx 970 with a 1tb at 7200rmp and a 240 SSD with 4 Fans
Can't answer....some cards are longer than others:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127832
MSI Card is Card Dimensions (L x H) = 10.59" x 5.55"
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125684
Card Dimensions (L x H) = 15.9" x 9.3"
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125685
Card Dimensions (L x H) = 12.2" x 5.08"
http://www.corsair.com/en-us/vengeance-c70-mid-tower-gaming-case-arctic-white
C70 Maximum GPU Length = 320mm ~ 12.6"
If ya worried about length, I'd look at the Phanteks Pro..... more features and fits longer GFX cards...
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=Phanteks+pro&N=-1&isNodeId=1
Graphic card = 347mm or 472mm (without HDD Cages)
I'd also suggest a current generation CPU / MoBo ... the CPUs are same price.... MoBo (Z97) maybe $10 more
