Will a virus scaner program help?
awesomedude911
323
so i have a gaming rig and was wondering if i should get a virous scaner bc windows is telling me that i should.
ive hear that it makes boot times slower.
should i have the virous scanner on my ssd or hdd?
is it unlikly to get a virus?
what programs do you like?
sudjestions/coments?
Thanks!!
If you don't mind a virus ridden system that crashes every other second then go ahead and run without protection. On the other hand if you prefer a smooth running system then you need to have a good anti-virus/malware suite. As the free ones go I recommend (in no particular order) AVG, Microsoft Security Essentials, & Avira. Suppliment with Malwarebytes and you'll keep your machine nice and clean.
