Yes it should fit no problems. Can you show me which Wifi card you are thinking of?
If it is something like this which goes into any PCIe slot then yes as they tend to be very thin.....
https://www.amazon.co.uk/Ziyituod-AX2974Mbps-Wireless-Bluetooth5-0-Dual-Band/dp/B07YZ7J8QD/ref=sr_1_2_sspa?dchild=1&keywords=PCIe+Wifi+card&qid=1596544372&sr=8-2-spons&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUE4N0s5SlVNQVJSRUgmZW5jcnlwdGVkSWQ9QTA2NDY5NzZRRjFMQjJYVk4zMU4mZW5jcnlwdGVkQWRJZD1BMDc1MTMyMzEyTElQSUtNSklWNFgmd2lkZ2V0TmFtZT1zcF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl&th=1
Thanks! I appreciate your help!Yep the TP Link will more than do the job. Heat sink should not be an issue as it is fairly low powered.
Wow! Thanks a lot for showing me this. My mind is at ease. lmao your ARGB looks awesome btw 😀No problems at all and just to show you, I have a Soundcard installed in my last PCIe Express slot with roughly the same space as you have and my Sound card is thicker than the TP Link Wifi card....and there is more than enough space...As the TP Link card is so short, airflow for your GPU should be okay...PS Ignore the Unicorn Rainbow PC, could not help myself its as though ARGB is catching...beware!!!!!!
View: https://imgur.com/Hq0oxeL
