Will a wifi extender work?
conaelan
39
I just built a gaming computer and bought a wifi adapter to connect to the motherboard to get internet. This computer is upstairs in my room, while the modem and router is downstairs. I noticed that while I was trying to download League of legends that the speed was only 40 kbps. So I was thinking of buying a wifi extender to put up in my room to get a better connection. My question is will this work and what is a good one that is fairly cheap and has a speed of 300 mbps? Thanks in advance.
If you want 100% performance, yes.
If you want 75% performance, powerline adapters.
If you want some random performance that drops all the time...WiFi.
If you put a extender/repeater/whatever in the same place as your PC, it will see the same crappy signal as your PC does now.
What you have:
Router--------------------------------------------------PC = crappy signal
What you want:
Router--------------------------------------------------Extender-PC = similarly crappy signal
What you need:
Router------------------WiFi Extender------------PC = maybe better signal
What you really need:
Router------------Cat5e----------------------------PC = 100% performance
Are you getting your wireless signal from the router or the modem. Perhaps you ISP has a better model modem if that is the case. Mine offered me a free upgrade and the new models offers much better performance. For gaming I don't recommend wireless connections, keyboards or mice. Perhaps you can use a power line adapter kit.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704164&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Powerline+Networking-_-N82E16833704164&gclid=CIvvkbTZvcgCFQ9rfgod_VoEow&gclsrc=aw.ds
This depends:
Is this your house, or your parents house?
If yours, string the cable.
If your parents...how amenable are they to creative wiring? Done right, no one will ever see it.
Very well put, if this is his folks house I think the Powerline is his best option. If it is his I'd run the cable.
