F fireokillz Honorable Dec 29, 2017 12 0 10,510 Mar 14, 2018 #1 Do you know if an xeon X5460 would work in the p5b deluxe? Thank you
Solution W W william p Mar 14, 2018 It looks like it here. https://www.delidded.com/lga-771-to-775-adapter/3/#asus
A antonio.parrot Honorable Jan 17, 2018 67 0 10,710 Mar 14, 2018 #2 I think not. P5B deluxe has max. FSB 1066 and X5460 needs 1333. Upvote 0 Downvote
W william p Splendid Sep 22, 2010 3,788 100 30,340 Mar 14, 2018 Solution #3 It looks like it here. https://www.delidded.com/lga-771-to-775-adapter/3/#asus Upvote 0 Downvote Solution
W william p Splendid Sep 22, 2010 3,788 100 30,340 Mar 14, 2018 #4 It looks like you will need a certain BIOS to run that. The one for the Q9650 is probably the closest match. http://www.cpu-upgrade.com/mb-ASUS/P5B_Deluxe.html Also use Vista drivers in Win7 , unless 7 drivers are available. And then there's this. http://www.userbenchmark.com/System/Asus-P5B-Deluxe/2357 Upvote 0 Downvote
