Will all of these parts work together?
jdklgn
Hey, this is my first time building a computer and I am wondering if anybody can help me figure out if all of these parts match. Thanks! 😀
1x Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
1x HANNspree By Hanns-G HF225DPB Black 21.5" Full HD WideScreen LCD Monitor w/Speakers
http://www.newegg.com/Product/Product.aspx?Item=N82E16824262011
1x XFX HD-687A-ZHFC Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150561
1x OCZ Fatal1ty 550W Modular Gaming Power Supply compatible with Intel Sandybridge Core i3 i5 i7 and AMD Phenom
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022
1x G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
1x MSI 870S-G46 AM3 AMD 870 SATA 6Gb/s ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130590
1x AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
1x SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Biostar motherboards aren't the best out there, as you can see from the feedback...You can choose one from Gigabyte,Asus,Asrock or MSI. Secondly you don't want a green drive as your OS HDD because they are slower...Also get a 2x4GB kit instead of 4x2GB at 1.5v as Intel suggests... No reason for i3 2105...the normal 2100 is just fine...and you can also check AMD's Phenom ii X4 along with an appropriate motherboard
I edited my list according to your comments. Do you have any more suggestions?
I think the only difference between the i3 2100 and 2105 is better graphics built in to the processor .
Since you are using a graphics card anyway you are paying extra for nothing since the stronger graphics will never be used
The green hard drive will slow boot and loading times . It saves a watt or two of power , but its not enough to be worth slowing your computer for .
The samsung F3 1 terabyte is the fastest and best priced 1 terabyte drive
Better now...but here's how you can make it perfect 😉
Get this case instead which has USB III in front panel
LIAN LI Lancool PC-K57 Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112318
Along with this PSU, which is manufactured by Seasonic. It's 80+ Bronze with 550W and 44A from 12V Rail which means it can easily support even high end cards like Radeon HD 6970
XFX Core Edition PRO550W (P1-550S-XXB9) 550W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
You don't have to spend 10$ more for the 965..955 is the same CPU and thanks to Unlock Multiplier all you have to do is go to the bios and give a touch more...and BAM! Your 955 is now a 965 😀
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
I would also prefer a SB950 AM3+ motherboard. This 970 model from Asrock offers 8x / 8x Crossfire or SLI, while all the other 970 motherboards are 16x / 4x...This results to better (way better) perfomance if you plan to SLI or Crossfire without spending a lot of $$
ASRock 970 EXTREME4 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157262
Everything else is fine!
