Will all these fit/work?
Jacob Hofmeyer
17
Hi this is my 1st PC and I want to build to build on my own and here is what I have
MOBO -MSI Socket FM2/AMD A75/DDR3/SATA3&USB3.0/A&GbE/MicroATX Motherboard FM2-A75MA-E35
Memory - Western Digital Caviar Blue 500 GB SATA III 7200 RPM 16 MB Cache Bulk/OEM Desktop Hard Drive - WD5000AAKX
G card- Galaxy GeForce GTX 650 Ti Boost 2 GB GDDR5 PCI Express 3.0 HDMI/DVI/VGA SLI Ready Graphics Card, 65NPH7DN7WGU Graphics Cards 65NPH7DN7WGU
Case- Rosewill Micro-ATX Mini Tower Computer Case with Dual USB 3.0, Dual Fans and 12.5-Inch Card LINE-M Black
Power Supply -Corsair Builder Series CX 430 Watt ATX/EPS 80 PLUS (CX430)
RAM -Corsair Vengeance Blue 4GB (1x4GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CMZ4GX3M1A1600C9B)
CPU -Advanced Micro Devices AD750KWOHJBOX 100W Quad Core Graphics Processor 3.4
Those will all work together just fine, but I would almost just swap out the fm2 for a am3+ fx 6350 which will give you more performance and from what I've seen less heat. You will also be able to overclock it higher as well as I think it might be cheaper than that apu
