Sorry to bother but am new to PC Gaming and decided to build it my self as it didn't look too hard and doing so makes it so much cheaper. After a week of searching I have finally choose my components which are all listed below including where am getting them from (ebuyer) and was just wondering if they would all work fine together for example do i need a bigger power supply, would i need more fans in the case etc, And if i do please say what i need to change. I would really appreciate your help.
Thank you, Reiss
CPU - i5 3570k 3.4GHz
http://www.ebuyer.com/349029-intel-core-i5-3570k-3-4ghz-socket-1155-6mb-cache-retail-boxed-processor-bx80637i53570k
RAM - 8GB Ram ( 1 x 8GB )
http://www.ebuyer.com/339598-corsair-8gb-ddr3-1600mhz-vengeance-memory-cmz8gx3m1a1600c10
Graphics card - GTX 780 3GB GDDR5 6008MHz PCI-E
http://www.ebuyer.com/508196-evga-gtx-780-3gb-gddr5-6008mhz-dual-dvi-hdmi-displayport-pci-e-graphics-card-03g-p4-2781-kr
Hardrive - 2TB Hardrive SATA 7200RPM 64MB Cache
http://www.ebuyer.com/319641-seagate-2tb-barracuda-internal-hard-drive-st2000dm001
Case - Coolermaster HAF XM Case
http://www.ebuyer.com/389854-coolermaster-haf-xm-gx-lite-700w-haf-xm-gx-lite-700
Motherboard - Gigabyte GA-Z87X-UD4H Socket 1150
http://www.ebuyer.com/507042-gigabyte-ga-z87x-ud4h-socket-1150-hdmi-displayport-dvi-atx-motherboard-ga-z87x-ud4h
Cooler - Corsair Hydro Series H60 2013 Model
http://www.ebuyer.com/411328-corsair-hydro-series-h60-2013-model-high-performance-liquid-cpu-cooler-cw-9060007-ww
Optical drive - iHAS124 24X Internal DVD Writer with SATA
http://www.ebuyer.com/410560-liteon-ihas124-24x-dvd-rw-dual-r-ram-sata-drive-internal-black-ihas124-19cu
Wifi card - TP-Link TL-WDN4800 Wireless-N450 PCIe Adapter Wificard
http://www.ebuyer.com/291714-tp-link-450mbps-wireless-n-dual-band-pci-express-adapter-tl-wdn4800
Power supply - GX Lite 700W PSU
Software - Windows 8.1
Thank you, Reiss
